I may have put A body Lower Control arms on a B Body?
The sway bar tab is at the Bottom....
I had a bunch of Lower control Arms apart....
73 A Body I guess is a similar Lower Ball Joint to 69 B Body
I used the B-Body Pins to go through the K Frame....
They bolted up but.....
The 69 Sway Bar comes real close to the strut....
Actually hit on the Passenger side?????
Is there a dimensional difference in the 2 arms?
I aligned the car and it drives great!
I just found this
I
