Re: New block, tight cam, fix?
[Re: blue_stocker]
#3071835
08/27/22 01:56 PM
08/27/22 01:56 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Because of where you are at now, John's idea is the easiest fix. Just use a whizzer wheel on your air grinder and an old camshaft and cut those little grooves (mine are straight) in the cam. Then stand the block on it's bellhousing and using oil and a drill and cut the bearings to size. Having said that, now I use Cab's way and do the bearings one at a time, test fit, and use a bearing scraper (or the side of a flat head screwdriver) if needed.
2011 Drag Pak Challenger
Entire Thread
gregsdart
08/27/22 02:43 PM
Uberpube
08/27/22 03:26 PM
John_Kunkel
08/27/22 03:50 PM
Tig
08/27/22 08:03 PM
madscientist
08/28/22 12:08 AM
hemienvy
08/28/22 12:24 AM
quickd100
08/28/22 12:30 AM
Cab_Burge
08/28/22 01:07 AM
fastmark
08/28/22 11:51 AM
Chargerfan68
08/27/22 04:26 PM
Cab_Burge
08/27/22 04:39 PM
blue_stocker
08/27/22 05:40 PM
rickseeman
08/27/22 05:56 PM
469runner
08/27/22 06:22 PM
gregsdart
08/27/22 07:17 PM
Craig J
08/28/22 01:45 PM
Cab_Burge
08/28/22 06:58 PM
Kern Dog
08/28/22 07:46 PM
merpar
08/28/22 02:15 PM
440Jim
08/28/22 02:22 PM
A727Tflite
08/28/22 08:16 PM
fast68plymouth
08/28/22 08:35 PM
gregsdart
08/29/22 06:30 PM
Cab_Burge
08/30/22 12:59 AM
