Originally Posted by Sniper
Problem is no one makes the power transistor these boxes used to use, so they got redesigned to use something still being made, poorly redesigned that is.
I did some research into this a while back, there is (was?) a similar power transistor that could have been used, but it was more expensive. IIRC and it was a couple of years ago when I did the research, that transistor was something like $30 each from Mouser.
Do you know what the part number was for the replacement? I have connections for obsolete components and may be able to find them
