I use Permatex high tack spray a gasket on pretty much everything https://www.permatex.com/products/g...x-high-tack-spray-a-gasket-sealant-6-oz/
I also started using valve cover studs instead of bolts so I know the gasket is where it needs to be.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
