I have a 93 dakota I want to swap in a 2.76 gear in place of the 3.55 gear, is there any year difference or anything else I need to be on the look out for while looking for gears? I have a sure grip from a 2002 durango R/T, will it work in the older dak diff? Are used gears OK to use as long as they look good? If used is a bad idea where does a guy find new ones? What about the 2.45s? they need a different carrier correct? Can I use a limited slip carrier from an earlier car in the 8.25 with the axles in the truck if I find a deal on a 2.45 with the LSD?
