Quote
Do you jiggle or touch and move any of the wiring when it quits?
Had this happen to me. Car just shut off. It restarted and I got home. When getting out, my foot brushed against the ignition switch connector at the base of the steering column. The engine hiccupped. I grabbed the connector and gave it a jiggle and the car died. It was just sheer luck that I found it that quickly. Check all your connections.
