Originally Posted by PDR Dude
I believe I discovered the problem. The rear cable mounting brackets were incorrectly located and welded to the frame to far back. Will need to remove the brackets and move them forward. Will take measurements from a couple other Cuda’s I have to determine the correct location.
up Thanks for the update beer I have had MANY head scratchers over the years on customers cars hop
