Its obviously too low and hits the manifold on the side. Can a spacer be used to lift it???
Dave, You also need the spacer because the manifold is for a spread bore carb (primary butterflies are smaller than the secondaries) and the Eddy is a square bore (all 4 butterflies are the same size)
![](/ubbthreads/images/graemlins/2231195-dggif.gif)
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
