When you do an oil change, adjust the back brakes. Yes they have self adjusters but that only helps when you back up. How much time is spent going forward using the brakes compared to reversing and using them? Doesn't take long before the adjusters have no effect. Simplest way I found around that was to manual adjust them at every oil change.
Carl Kessel
