Originally Posted by Cab_Burge
Originally Posted by jyrki
. Basically you can do pretty much anything with a 383 that you can do with a 400 or 440.
Don't forget that all the 383 blocks have the same thin main webbing just like all the RB made before 1973 had puke work
if you can find a decent 400 block build that after having it sonic tested well scope up wrench twocents
Exactly. Also as has said, better heads. Tunnelrams make torq...
