The current combo is
383 727. 8.75 with a 355 gear and 26.8 inch tires
I’d like to run a gearvendor unit to lower my 65-70 mph cruise rpm by 400 or 500 whatever it is
I’m also running a 2500 stall converter now. The cam is a 230/236 comp grind that has issues wanting to push through the brakes
Hence the upgrade to the 2400-2500 stall converter
What’s everyone’s opinion. Will the combo work?
I’d like to be 2500 rpm as close to 70 as possible
if You Like Gremlinsteve. Gremlinsteve Likes You.
