Originally Posted by DusterKid
I use the Mopar Performance Black Cast ones on my Trick Flow 240 heads using the Moroso rubber with steel valve cover gasket. Haven't had any issue or leaks in the 4 years I've had them on. I usually check the rocker arms once a season and reuse the same gaskets.
i dont think those are being made anymore.
