The problem was the castle nut threads were in bad shape and there was a slight burr at the cotter pin hole. I found another nut and cleaned the threads and with some force pushing down on the tie rod end, it torqued to spec.👍
Thank you everyone.
1970 YO7 A66 [Canadian Export] F8 Challenger
340 (Currently in shop for stroker assy.)
