Looking to confirm the valve stem length used with the 70-71 15x7 2944390 rallye wheels? I know they take the 1/2" extensions part # 2660315....just not sure on the actual valve stem length? Also, when the extension is installed is the connection to valve stem below the surface of the trim ring? Thanks in advance. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
