BUT there is one thing on your filter that you posted that is like the O.E. filter and is correct and that is the outer round hole screen and that is the round holes are "beveled" around the edge. Don't know if someone copied or saw that detail but I think that the square mesh inside screen is still the way to tell an O.E. CA332 air filter.
I'll look at the NOS filter I have for comparison...one note regarding the "bevel", you won't see that on early filters, because the "bevel" was the result of prolonged tool wear punching the outer shield mat'l.....that's info straight from the original FRAM engineer that did the leg work making the sixpack and oval elements for Chrysler
