Originally Posted by DUFFMAN
Originally Posted by poorboy
Try swapping the coil packs with other cylinder coils and see if the misfire follows the coils to the different cylinders.
Did you do a compression check before you pulled the heads?
I'm sort of wondering why you started by pulling the heads?
Did you do other tests before you pulled the heads?
Change the exhaust manifold studs while the heads are off.
The heads were pulled due to broken exhaust manifold manifold hardware. All the hardware was replaced along with the manifolds.
The engine ran great before the heads were pulled. No check engine light or anything. I don't have a way to check compression. I have a compression tester but it's not long enough to get down the spark plug tubes.
Now you say it developed this after they pulled the heads. Massive vacuum leak.
