69 440 B body would use the 143 tooth flywheel. Not normally a hemi flywheel, but I do think the aftermarket supports one with 8 bolts.
In 1970 mopar went to the 513 Alu Bell house for the 130 tooth flywheel for all BB motors including hemi.
But as stated, the actual Bell housing determines the flywheel size so that the starter engages.
