Indy 4.84 bore space block is 4.563 bore. Mopar made 5" bore space Pro stock Hemi heads and blocks. New Century blocks makes a 4.900 bore space block that they will put various head bolt patterns on. I thought about having one made with the Pro Stock Hemi bolt pattern on. You would need to put the lifter bores in the correct locations. None are easy or cheap.
