Ok. Someone posted an answer on for b bodies only to your question. He included pressures for each application. I was remembering that the c body and TA pump shared the same pressure and part ͏N͏o. I don’t have my parts book here at home. Do they have different valves or just a valve that is adjusted for the pressure? In other words, can you take the valve out and see the difference?
