Originally Posted by JohnRR
Originally Posted by Rhinodart
Here is a pic of a factory block with the drilled and tapped holes in the boss's of the oil pump mount...
Looks like the block I gave you with the Mcode dart ?
Chrysler did this because they eliminated the bosses on the block casting under the cylinder head that were used for mounting 440's in 65 thru 68 C bodies.
Not the block that came with the M-Code I got from you, that went with another M-Code I sold a couple years ago. This block was from a 68 GSS Mr. Norms car that I still have...
JB Rhinehart, Realist
A-Body's RULE!
