Anyone have some extra motor mount bolt washers they'd like to get rid of? smile
I'm in the middle of swapping in a 5.7 motor and found I need 3 washers.
I have 1, its a weird size, or I'd just go to HD
The washer is 5/32 thick (0.155"), ID 7/16, OD 1.5"
The reason I want 4 is due to clearance, I had to cut the welded nut on the motor mount off, and will be using a standard nut with added washer.
Thx
