Hydraulic lifters can only pump up if valve control is lost. (So, valves would have to float or bounce first in order for that to happen).
If you have a valvetrain set up on the light side, or it's just unstable for whatever reason and it can get into loft/bounce, less preload would probably be better but I just try to avoid that alltogether.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700
