I will look into the Griffen and Glen Ray radiators. I don't care if there are any numbers on it as the car is not original anyway but I will also look around for a factory big block radiator. I have a related cooling question as well. As far as the fan/clutch go, I was planning on using a Mopar Performance viscous fan kit I have in my collection of parts. It is the kit with the five blade fan. Will the five blade fan work well or should I go with a factory seven blade fan?
I don't think you'll have enough room for that clutch fan. The BB A body cars are usually really short of space unless you've made modifications. Have you ever had this car together or is this the first time? I used a 26 inch radiator in my Duster and I found room for a clutch fan, but I had to move a lot of stuff around.
