Originally Posted by GomangoCuda
That cam will like more timing at idle. Try 20° or more. Then adjust the Carb.
Agreed.
Fundamentally, I like to have the basic ignition curve sorted out before trying to dial in the carb.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
