Originally Posted by Cab_Burge
Originally Posted by dragon slayer
You can find it in the service manual. 3.400" + or- .005" Length. 204 grams. 1.031-1.3012" Dia
Do you mean to post 1.031 to 1.032?
Yes I did. Corrected post.
Wall thickness not given. But that is not critical if the pin is spec'd to a hemi. But I guess you could figure it out with density and the weight. Solve for thickness since you have the area measurements. grin
