I'm going to be using a 15/16 bore 2-bolt aluminum master and a 4-bolt to 2-bolt adapter. I'll use a standard gasket between the adapter and firewall. I assume it would be a good idea to put a gasket between the master and the adapter too? If so, is anyone making one for the 2-bolt masters or do I need to make one? I will not be using a booster.
