So I found the led replacement bulbs instead.
went to home depot and found some with a good warranty that way I could take them back.
some wire with or without the ballast. good or bad I don't think it matters.
I got the kind that will work either way, and if it is dead, I just need to rewire at some point.
don't know how many lights you have or if that is more cost effective than buying new fixtures.
I am pretty sure mine are GE bulbs.
Thanks I'll check that out. Its possible that some of my fixtures may not work with those. Some of them have the bulbs with one big pin on each end and some have the more typical 2 pins on each end.
