I had an 87 Diplomat I ended up swapping a 360 and an A833 into. Swapped out the original 7 1/4 (2.26 gear) and rear suspension for a cop spec setup out of an 87 Gran Fury, 2.94 gear.
It ran much better, lol.
"It ran much better". You couldn't undersell that point any more if you tried, LOL.
FMJs have two problems: they've been overlooked forever and there is near-zero aftermarket support. You need to be very skilled, very patient, and very committed to the task. I've owned six M-bodies (including the above-mentioned car) and two J-bodies (Mirada and Imperial) and they are a great platform for a build that just doesn't have the aftermarket backing of other platforms. My late-B Charger has more options.
