I agree, build it yourself for your specific situation.
Use quality parts. Not auto part store stuff. Read and make sure you understand grounds and good construction techniques. Use Weatherpack at a minimum. Deutsch if you want the good stuff.
I like ARC stuff, but prefer the 3100 panel for most applications. Or build your own with good rocker switches.
If the results don't match the theory, change the theory.
