Originally Posted by 57Fury440
The driveshafts were not painted from the factory so they all rusted. They are pretty thick metal. Are you taking it down to replace the universal joints? If you are then I would clean the driveshaft as much as possible and coat it with a good rust inhibitor. Most of the driveshafts I have seen on the older cars are rusted and pitted.
Shafts were not always painted. I would not want anyone touching my unpainted shaft.
