Almost certain no bag, Cruise is in the horn part 92 wipers-speed adjustment and hi lo are in the turn stalk. 88 has a standard column like the older cars-trucks. I see no problem making the steering shaft longer to fit truck. The bracket that holds the throttle and cruise is a little different but can be changed. 92 has a mapp sender 88 dont. If I change over to the 360 I think the 8-1/4 rear should be ok too. Work in progress for now
