Originally Posted by Cab_Burge
It depends on the rocker arm used if you need through the pushrod oiling or through the adjuster oiling to the pushrod tip scope
Some of the high end extruded aluminum shaft mounted rocker arms use oiling through the adjuster in different ways, some have several threads missing for the oil passage and others machine it in the rocker arm adjuster hole scope
I'm using Stage V 426 Hemi lifters and need to order the adjusting screws. Thank you Cab I understand now!
