Originally Posted by Glen440
Depends how creative you want to get. I modified the stock throttle body to take the original throttle cable and a lokar TV cable for the transmission. I welded a splined shaft onto the shaft of the throttle body, it uses the stock TPS. I had to make my own IAC which does not work the best when its cold. When its warm its fine. I have not looked into aftermarket throttle bodies, I worked with what I had.
I'm likely not far from you, work in Toronto.
Thats a pretty genius setup! To be honest, I don't mind spending a bit of money if it will be easier and actually WORK. The procharger setup I have is meant to work perfectly with this truck intake that I also have on my core motor, its just a matter of getting a throttle body setup for it that could work.
