Originally Posted by ChrgrCuda
Greetings
I am about to install a 440 with EFI into an 85 Dodge D100. Does anyone have any suggestions on where to mount the fuel pump for the EFI?
Most will tell you it should be mounted in the tank. I mounted mine on the frame rail close to the tank, 8 plus years no problems.
Make sure you place the fuel regulator after the injectors, and on the return line to the tank.
My Monster are real!
Living within your means makes life pretty easy.
