I have a '62 Fury I was considering running at the local autocross once in a while (6-8 times a year). it will be street driven most of the time so it needs to drive well on the road.
I have plans for a mild built 383 with a 727.
What are easy/fairly cheap mods I should consider to have fun? I'm guessing sub-frame connectors, larger t-bars, shocks, sway bars and maybe disc brakes up front.
Anything else you can suggest that isn't a lot of money (e.g. aftermarket front k-member, etc)???
Just copy my build. I've tried a bunch of different parts on my car over the past 30 years and have figured out what works and what doesn't.
