Yes…a diagonal track bar. So, after each IC or preload adjustment, you have to readjust the track bat for axle lateral position? Seems like alot of additional work for each adjustmant. Really didn’t want housing location to change with each 4 link adjustment. Do you all actually readjust diagonal bar after adjusting 4 links, or you just let it be.?
Thank you
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
