HI, I have a 68 b body power steering box issue.
Unit was working fine, but was seeping around the spool valve body. I removed valve body and installed new seals.
Reassembled and began adjust to get spool unit centered. It will center but when turned left or right is will continue to drift in that direction. I have done extensive reading on this issue
My spool valve moves freely in housing bore. The spool lever and spring are not damaged and look fine. I don't think there is any issue with the box itself. Has anyone replaced the entire spool unit, to solve this drifting issue?
Sure appreciate any thoughts.
