Originally Posted by 360view
Originally Posted by Andrewh
safety torx. and depending on how much force you need, you can wedge a flat head in to one side and get it to turn.
or if it is really small use a flat head to break the center pin out and use a regular torx or allen wrench.
I have some success using a pin punch
to first knock the center pin left, then right, then down, then up.
Rinse/repeat/etc
and it will snap off
Sounds like you might have a few toilet stall doors you might want to sell...........................................just kidding grin wink
