The biggest downfall of the V10 was the owners and their lack of cooling system maintenance. I don’t recall much of a head gasket issue as much as porous heads but that was back in the mid 90’s. The corrosion probability was quite high as they still used the green 3yr coolant and the more often they were flushed, the better.
