Here are the dimensions for one of the pans Andy showed that Charlie made for me. Its been a good pan for me. There is a front baffle, a rear bolt in baffle, and a swing trap door below the center link tube. You can see the baffles in Andy's picture.The factory dipstick location will not work. A dipstick tube was fabbed to fit in the right side kick out. Its calibrated to read oil in the pan, not the engine itself. If there are 7 qts in the pan it never fluctuates. Even at 6 qts the only time I saw anything was on hard braking. The center link hole may need adjustment for your engine placement. But a good welder should be able to copy it.
Doug
