Originally Posted by slantzilla
73-76 7.25 with BBP has a larger wheel bearing on it Jim. The spacing for the brake is also different.
I assume Dr Diff's new LBP axles would use the normal 4.5" pattern brakes so they ought to have the same spacing as the 73-76 axles do.
