And from the rear. Had to put it this far back to reduce toung weigtht. It wanted to sway when a semi assed me if I pulled it up farther. Now its steady.
Are you using a weight equalizer hitch... they are
almost a must. I hauled my 26' with a 5.9 1500 for
5 years with the EQ hitch and it pulled great, stopped
great(both axles with brakes). With the EQ hitch you
can shift the weight around without upsetting things.
I used the 1200 lbs bars
