The byproduct of propane combustion is water. Keep in mind that moisture condenses on any cold surface. So you go out to your cold shop and fire up a propane heater for a few hours and it spews moisture which condenses on everything in the shop. Bare metal will rust and mold will form on everything else - not overnight obviously but eventually.
