From cold, a few pumps of the gas pedal and go from there. Hot, just turn the key. Ignition is always on while cranking, We use an MSD Grid, from memory it has about 18 degrees of timing at 200rpm rising to 36 @ 1200. We take 4 degrees out in 3rd gear. Mopar (Denso?) mini starter too 12.5:1 580. HTH's ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
