I put a set of dual electric fans out of a 98 Dodge Intrepid on my 2002 Ram van. Did the same mod on a 92 Dakota as well. Shroud and both fans fit damn near like it was made for that application. Had to change the wiring on the fan harness to get both to run at the same time but it was fairly simple. Van now runs at 180 on all but the hottest days. Was 205 or so prior to installing the electric fans.
