Originally Posted by dragon slayer
Originally Posted by Cab_Burge
!970/1971 was 6 quarts only, the 1966 to 1969 were not 6 quarts tsk
down Sorry Cab you are wrong. 66-67 was one pan 5qt. 68 they moved to the 6 Qt pan. 68-9 same pan. 70-71 went to the hemi/6pack 6qt pan. Different shape probably because of sway bar change. But 68-71 are 6 qt pans.
So is that considered a 7 quart system? 6 in the pan and one in the filter?
