Once you find the interference by measuring you will know. Although the old cam with grooves trick works it makes I cringe for a number of reasons. Unless you pull down the engine that is likely to be your solution if you dont find iszue with the cam journal size. In my experience there usually a few tight cam journal bores towaed the back of the block.
