Originally Posted by moparx
chasing wiring issues, especially caused by others - man and beast alike, has been at least one reason i have no hair on the top of my head. biggrin
beer
I've fixed several stock Mopar wiring harness in the engine compartment and under the dash harness that had melted connections, worn insulation and so on that lasted a long time up
Slice the tape covering and remove, cut, out the bad part, twist in a new piece of the same size wire and color, solder and heat shrink cover it and retape it: up:
