for the large part it's the same engine. take the Etorque off and use the engine as is. the Crank sensor is bidirectional, The transmission is different if you intend to use the 8 speed though. it has a fluid accumulator inside for quick restarts.
00 dakota R/T 6.1 Hemi swap.
07 Charger R/T G3 426 Hemi
68 AMC AMX 5.7 Hemi swap
