iagree up Me too on the main studs and aluminum main caps now that we can't buy the Mopar Ductile iron main caps anymore whiney
Cab.......are you saying you prefer the iron over aluminum caps if available?
Yes
Based on the ductile iron material expansion rate at difference operating temps being very near the block cast grey iron rate
I've used both with no failures yet
I'm sure my current S/P 400 block E85 bracket stroker motor will have a major failure first run next year
I sincerely hope not
